RE: Servos are bad?
My test is to hold a control surface and slowly move the stick to the two extremes. Not really restraining the control surface . . . just keeping the model on it's wheels but lifting or tipping it enough that the control surface is supporting some of the weight - maybe 30%. If it "skips" noticably or fails to return to the zero point you have a bad servo/missing gear teeth.
