RCU Forums - View Single Post - Painting the JMP Firebird, a tutorial
Old 04-21-2010 | 07:30 PM
  #35
LGM Graphix's Avatar
LGM Graphix
My Feedback: (22)
Default RE: Painting the JMP Firebird, a tutorial
Ok, so lets get started turning pretty paint into perfect paint!
First here are the materials I use when polishing.
Picture 1. First of all, 1500 grit sanding disks. I really cannot express how important it is to use a GOOD high quality paper for these stages. Cheaper brands do not have consistent Grit in them and can leave deep scratches that you will have a very hard time getting rid of. The 3M disks are phenominal, they aren't cheap, but they will last a fairly long time, much longer than just a wet/dry sandpaper will.
Picture 2. This is part one of the magic process, 3M trizact 3000 grit disks. These are painfully expensive but they are phenominal, they leave a perfect uniform sanded surface and will remove the 1500 grit scratches with ease. These disks are around $100 for a pack of 15, but they are worth the money for all the time you will save in the end. (sorry about the blurry picture)
Picture 3. 3M's extra cut polishing compound. Again, it's not cheap, but the results are definitely worth it, when it comes to these products you do get what you pay for.
Picture 4. 3M's swirl remover for use after the extra cut compound.
Picture 5. 3M waffle polishing disk for the extra cut compound
Picture 6. 3M waffle polishing disk for the swirl remover
Next I will detail the polishing process.
ID:	1422342   Click image for larger version
ID:	1422343   Click image for larger version
ID:	1422344   Click image for larger version
ID:	1422345   Click image for larger version
ID:	1422346   Click image for larger version
