RCU Forums - View Single Post - Yellow P-47 Build!!
Old 04-21-2010 | 08:31 PM
gmohr's Avatar
gmohr
Default RE: Yellow P-47 Build!!
Hi again!
Progress is good. I've got the servo trays installed for the tail and the throttle. I've relocated the fuel tank to the throttle servo platform so it is close to the CG, and I'll utilize the stock fuel tank location for the ignition components. I plan to use an A123 2300 pack for ignition, along with an opti-kill switch. That plus the DA ignition module will take up most of that space.
I've also got the stab joiner provided for and the dowls glued in. And lastly one side of the stab center section glass.
Regards,
George
ID:	1422413   Click image for larger version
ID:	1422414   Click image for larger version
ID:	1422415   Click image for larger version
