RE: low throttle setting - will it hurt the engine?
Jezmo,
This applies to pre-2008 engines, I don't know how old your engine is. The big end bearing doesn't seem to be strong enough, and it is recommended to check it after 30 hours. One or two extra head shims to lower the compression will make it last longer. The newer engines have a larger bearing.
