Hello Jeremy,
I pick this up at FL Jets this past March after the original owner had a minor landing mishap. [X(][X(]
Yes the rear section of the main fuselage took the brunt of the crash damage, also the clear canopy and the right wing tip.
The wing is now repaired; however, the live hinge for the aileron has been damage beyond repair so I removed the surface and have to decide if I want to repair with robart hing points or re-make a live hinge using the CA type of hinge material.
Got to love fiberglass fuselages...so easy to repair!
Turbine is a Jet Central Super Eagle...it should push it along
