RCU Forums - View Single Post - Another 'HOTS' only bigger !
Old 04-22-2010 | 04:51 PM
  #64
john josey
Default RE: Another 'HOTS' only bigger !
This is the first look i`ve had of the engine to be used, an OS 91 FX and by the look of it, it`s only had a few tanks through it, not a mark on the internals.
Drilled the holes on the bulkhead for the engine mount. The mount rotated to have the tuned pipe running down the centre of the fusalage and the height to suit the 70mm spinner lining up with the top of the fusalage.
The last jobs i managed to get done were the top sheeting between the bulkhead and former 1, the 3mm plywood 'ring' and the 1.5mm spacer to the back of the spinner.
Hopefully get the cowl done tomorrow.
