RCU Forums - View Single Post - Painting the JMP Firebird, a tutorial
Old 04-22-2010 | 05:41 PM
  #50
SPLIT S's Avatar
SPLIT S
Default RE: Painting the JMP Firebird, a tutorial
Hi Jeremy,
Job looks fantastic. One question for you though. I use the gray foam pads for my polishing and glazing, but have always used wool or wool blend for the compounding. How do you feel using the white compound foam pad differs from old school wool? I guess I'm concerned with the pad wanting to skip until it's loaded a bit. Any tips there?
And on another note, do you have someone helping as far as holding pieces while you are polishing? I usually use my CP7200P with 3" wool and the 3M 5725 3" gray waffles for alot of my work. I've used my big DeWalt with 9" pads, certainly quicker and more consistent results, but sometimes afraid I'll grab an edge accidentally and send the part sailing....
Dan
