RCU Forums - View Single Post - Motor incidence problem, NEED HELP
Old 04-22-2010 | 07:48 PM
Tall Paul
Default RE: Motor incidence problem, NEED HELP
I put a landing gear on this Gentle Lady and used a tractor and pusher power pod.
Adjusted so the plane would take off without any elevator, I had to reduce the downthrust on the pusher motor several degrees, so that the plane would accelerate to a level attitude on the wheels, and then fly off the ground as the speed increased.
The tractor pod needed no changes.
ID:	1423027   Click image for larger version
ID:	1423028   Click image for larger version
