RCU Forums - View Single Post - NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
Old 04-23-2010 | 08:32 AM
  #353
topgun427
Default RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
 belive I have a bad ESC for my p-51 I was testing eletrontics and adjusting rudder and such ran motor for about 30 secs or so at 1/2 to almost 3/4 throttle and motor stopped made a pop noise and came on at about 1/2 throttle for a couple of seconds then nothing.<div>Still have all other electronics. Disconnect battery and  reconnect I get no arming beep at all. Pulled out esc and it smells burnt motor also smells alittle burnt.Connected esc and motor and powered up and esc is very hot to touch can you send a replacement esc or do I need to send esc and motor to you to test the plane is a week old and has  not been flown. Order #  yhst-17210252890263-123006</div><div> </div><div>Thank you</div><div> </div><div>John</div>
