RE: Lets Try To Mold A Moldie!
Next,
#1 Mix a little epoxy on the scale, yes I got the scale at aircraft spruce too.
#2 Add in a little Cab-O-Sil which I got at ,,, All together now AIRCRAFT SPRUCE. dont add to much as it will make the epoxy to thick and brittle just add a little at a time until it is about the consistancy of ketchup ( I think there is an s in there somwhere but you get the idea )
#3 Put the mix in a little baggie, cut the corner off and squirt it in all of the hard to get to areas.
#4 I put it around the tail and stabilizer area.
#5 Since this airplane has rather large fillets as the orignal does I also put some in there.
D.E.
