ORIGINAL: Bax
Are you sure? It looks quite a bit like a Hanson Runaround.
The control surfaces on the Runaround go all the way out to the tips (Airl,elevator,Rudder) The Runaround also has a staight trailing edge. Hard to tell but it looks like the plane in the pix has a double taper wing. Landing gear is mounted in the wing on a Runaround(Most of the time)
