RCU Forums - View Single Post - Help!!!!! please
Old 04-23-2010 | 10:46 PM
giddyuperic's Avatar
giddyuperic
Default Help!!!!! please
Can anyone please tell me if I can use the DX7 radio and a AR6200 reciver and I want to hook up my rear stab servos on two channels. I have done it with a AR7000 no problem but when I try it with the 6200 and I get to the part on the radio where itsay aux2 the 6200 has only a aux1 and I can't get it to work. I have it working on my jet but that has the 7000 in it does this make a diffence?? Is there a way to change the aux2 to aux 1? When I try the arrow just skips right over it. 1.) Access the System Mode
a. Scroll to the Input Select screen and change AUX 2 to INH.
b. Change FLAP to SYS
2.) Press Access (Down & Select) once to return to the main screen
3.) Press Access a second time to access the Function Mode
a. Scroll to Program Mix 5 or 6.
b. Press Increase to activate the mix.
c. Set the mix as FLAPĂ* AUX 2
d. Set the rates as 100% for both up and down (move flap switch to move small arrow next to rates)
e. Set SW: ON.
4.) Press Scroll to Flap System screen and set flap values for neutral, mid and land.
Can you do this for the rear stabs on a AR6200??????????????????
