RCU Forums - View Single Post - 170 cdi Help
Thread: 170 cdi Help
Old 04-24-2010 | 06:34 PM
apereira's Avatar
apereira
Default RE: 170 cdi Help
Seems like you have an air bubble in the pump, just try to force some fuel by squeezing the tank or by using a syringe from the injector hose, check you don't have any damaged hose(pin holes), it's typical in new engines, once you prime the pump well it should not happen again, unless you run out of fuel.
