RCU Forums - View Single Post - Sebart Wind 110
Old 04-25-2010 | 09:28 AM
  #779
mdjohnson's Avatar
mdjohnson
Default RE: Sebart Wind 110
Thanks Wilson............over the last couple of months I think I have read every post at least twice and I plan to use your method of supporting the rear shaft. As far as more right thrust goes, I have been using a throttle to rudder mix on my Vanquish with great success. It takes a little more fiddling with the mix curves as it is not a linear mix but once dialled in it works well. If I do need more right thrust for a larger propeller I will probably use the same technique and mix rudder with throttle..........gotta love those computer radios!
Cheers
MJ
