Ignition/Ignition Battery Tray
For those that read my last thread...see what you think about this
This tray is for the ignition and ignition battery only. Now that I realize that the batteries are part of the ignition system as well, I have had to do some head scratching this weekend, but I hope this works. Criticism please.
This tray will be mounted in the nose of the plane and will give me about 7" of separation from ignition and receiver batteries and about 10" to the RX (even more from the ignition itself). I included a picture of the receiver tray. I went back and read the Futaba manual, and if I am reading correctly, this should be OK to orientate the antenna like this. This will give me the 90 degrees between antenna and will just fit inside the fuse without bending the "critical" ends of the antenna.
What do you guys think?
