RCU Forums - View Single Post - IR Emitter Location
Old 04-25-2010 | 09:38 PM
Pershing.Driver
Default RE: IR Emitter Location
The IR emitter holder is 6 mm inside diameter and the tip of the IR LED is 9 mm inset from the opening.
As for placement in a mantlet you should try to have it offset from the Apple that way you can hide behind a building and still have the IR emitter exposed.
