RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 04-26-2010 | 01:12 AM
  #766
cmoulder
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: nonstoprc
ZDZ40 with the scratch-built gas pattern (ama plan). I recall the plan calls for light tube used for heli tail boom. It worked pretty well. If you have the flange for the exhaust port, find some mop or broom with steel tube handles. At some point of time, I examined one such tube and found it is extremely light and can be map gas soldered to the flange. The coupler I used is pretty short (1'' or less and no metal insert).
I am using a home-made soft mount for the engine, and there is a 2-1/4" rise also needed for the header, which means it isn't just as simple as running the header straight from the exhaust. So simplicity is best with the exhaust header. It is working well now and it took a fair amount of effort to get to this point, therefore the old adage applies, "If it ain't broke..."
ID:	1425418   Click image for larger version
ID:	1425419   Click image for larger version
