RE: EXCEED MADHAWK 300 AIRWOLF???
ok the battery is no good so do not use it unless you know how to solder and fix broken joint, otherwise it's too dangerous to fix the battery and it's not worth it. When you throttle up without the motor connected to the ESC, does the swashplate level all the time?
Andy
