RCU Forums - View Single Post - Beginner with questions
Old 04-26-2010 | 11:20 AM
jdetray's Avatar
jdetray
Default RE: Beginner with questions
PZ -
The formula for roughly estimating flight time is:
(Battery Capacity in Ah/Motor Current in A) x 60 = run time in minutes
Get the Battery Capacity by converting from mAh to Ah. Simply divide by 1000.
Get Motor Current by measuring your full throttle current on the ground with a wattmeter. A wattmeter is a required purchase. Get one!
Let's look at a few flight time examples.
Example 1:
1500 mAh battery
power system draws 12A
1500 mAh = 1.5 Ah
1.5/12 x 60 = 7.5 minutes
Example 2:
1500 mAh battery
power system draws 18A
1500 mAh = 1.5 Ah
1.5/18 x 60 = 5 minutes
Example 3:
2200 mAh battery
power system draws 10A
2200 mAh = 2.2 Ah
2.2/10 x 60 = 13.2 minutes
Example :
3200 mAh battery
power system draws 20A
3200 mAh = 3.2 Ah
3.2/20 x 60 = 9.6 minutes
These calculations assume you are flying at full throttle at all times, a worst case situation. So actual flight times should be a bit longer.
Regarding charging time: By definition, any fully depleted battery being charged at 1C should in theory take exactly one hour to charge. In reality, there is some variation from this because the battery may not be fully depleted and because charging is never going to be a 100% efficient process. You should figure on at least an hour for charging a pack and plan your bettery purchasing accordingly.
- Jeff
