RCU Forums - View Single Post - Deception Build
Old 04-26-2010 | 01:13 PM
  #116
ChiefK's Avatar
ChiefK
Default RE: Deception Build
Ed,
As slow as I am, I may catch up with you soon. I've got the Deception canopy carved and somewhat hollowed from balsa block. Stabilizer and fin are mounted. Fillits are roughed in. Working on the cowl currently, and starting to shape the fuselage.
The engine (Webra Speed .61) sits so low in this fuselage, it looks too small for the airplane. Only the cylinder head sticks up above the fuselage top. Will probably see a little more when the fuselage top is shaped.
Are you painting yet, or are you going to plastic-kote your plane? I'm going to use Coverite (cloth) on the wing and paint the wing trim, then paint the rest of the airplane.
Where are you???
Greg
