RE: removing flywheel
Ended up with the hack saw, wasnt too much trouble, a friend ground down the funky nut that held on the flywheel, and is grinding down the whold flywheel basically to a tapered washer...wow walbro makes/made a lot of different carbs,,gotta make some calls about rings and rebuild kits for the carb...none of the small engine places stay in business very long around here....Rog
