RE: Breaking in an engine inverted.
I would suggest running the engine for a while on a engine test stand first. You can adjust it and get used to it before you mount it inverted.
it is a lot easier if you have problems being on a test stand to iron them out with.
Then after you have it running OK, then move it to your plane.
