RE: RE:
you dont need the cross formers if you dont want!! My fuse is built to planes with sheeting it is solid . I cut a big access p[lanel out the bottom of the fuse and put a servo tray in there which will also lock the unit up .. block up a bunch of foam around your engine sand to contour then glass them with z poxy !! watabing you will have cowls to fit perfect .. dont worry bout weight cause you are way over weight may need bigger motors .. I will put g26's on mind with ppg and retracts .. good luck dont forget cg
