Hinges
Suit:
CA hinges typically look very porus, and don't have a traditional "hinge" to them. You install tham as per gil suggests. If they are hard plastic, then they aren't CA hinges. Depending on the type of hinge, if you use CA on them, they will work their way loose pretty quickly. I usually epoxy mine in.
