BUSA Sopwith Pup and G38
I am building the 1/4 scale Balsa USA Sopwith Pup, I was planning on using a Zenoah G38. Here is my problem, with the rear exhaust the engine is to long by about a 1 1/2 inches. Has anyone used a G38 with this plane and if so how did you mount it? pictures would be great. Normally I would cut some of the firewall away at the bottom to make room, but the landing gear block is in the way.
Any ideas would be great.
