RE: And another CG Ultimate Build
Thanks for the reply Dan. I'm going with Hitec 645's for the elevator and rudder and standard Futaba 148's for the ailerons. I could use Futaba 301's for the ailerons but I'll have to buy another one (I need to cut the spending off on this plane). I'm not planning on moving the fuel tank but the 6v battery pack is kind of heavy compared to the 4.8 pack so I may be ok moving the battery pack far aft. What prop did you use with the YS?
maekju
