RCU Forums - View Single Post - KillerVolt
Thread: KillerVolt
Old 04-27-2010 | 08:16 PM
HRCules77's Avatar
HRCules77
Default RE: KillerVolt
1. This is my newly fabricated receiver battery I jacked from my mini copter (which is still in Canada). It's actually made up of 2 E-Flight 2S 800mah Lipos I paralleled. So I have a total of 1600mah which isn't bad. I don't actually need this pack except to keep the truck balanced and I'm happy it fits nicely into the space I needed it too.
2. You can see the Novak high voltage BEC I've mounted on top of the packs and if it weren't for balance, I'd run it direct from my motor's power source. Since the light works, I know it's a go.
3. This tiny little space is where the pack is going to be mounted...any wider and I'd be interfering with the steering assembly. This space is actually tighter now than it will be for the simple fact that I've got my Futaba S9551 low profile servo installed for measuring purposes until I fix the high torque one I blew out. I will gain an extra 5+ mm or so of room when the other one is installed.
ID:	1426584   Click image for larger version
ID:	1426585   Click image for larger version
