Displacement is part of the equation. RPM is another. The last part is how much peak power you're willing to sacrifice for midrange running and transition. If you calculate volume flow and size the carb for 60-80m/s velocity through the venturi it will be close.
Pe Reivers has a nice calc in his spreadsheet.
http://mvvs.nl/utilities.htm
