RCU Forums - View Single Post - Nelson Problem
Old 04-28-2010 | 07:53 PM
Bill Vargas
Default RE: Nelson Problem
Does the crank, with prop mounted and the backplate removed, spin freely without the top end installed? if not i would suspect a bent crank or a tweeked case and/or would try a different crank.
Is your piston and sleeve hard to install? If yes, your case or the sleeve is tweeked.
BV
