RE: Right thrust
Is the plane a tail dragger or tricycle gear. Is the problem during take off only or in flight? If only on the ground, check to see that the sterring wheel is properly aligned. If problem in flight, make sure all the flight surfaces are properly aligned.
I have two planes with no right thrust and it only affects take off roll to any degree. Once in the air see no difference.
Gary
