RCU Forums - View Single Post - Mounting the engine
Old 04-29-2010 | 11:24 AM
av8tor1977's Avatar
av8tor1977
Default RE: Mounting the engine
Nope, not needed. You can take off any mechanism on the back of the engine. Threads might be left hand...
When I am feeling ambitious, I cut the crank off just inside the rear bearing. Then I make a plug to go where the seal was. Loses a little bit of weight done like that, and there is one less place for the engine to possibly leak, but it is a bit "overboard" and not necessary.
AV8TOR
