RCU Forums - View Single Post - TP Pro Lite V2 question
Old 04-29-2010 | 12:37 PM
Glacier Girl's Avatar
Glacier Girl
Default RE: TP Pro Lite V2 question
Not stupid at all Johnny, stupid is the question not asked.
From the info you posted, I'd say dependent on the prop you are using, you should be good to go.
Just looked up the Bonanza, did you read the bulletin on it? Apparently some of the birds went out with only one wing joiner, a big no no. Also the bulletin gives the proper way of checking CG dependent of which landing gear option you used.
