RE: Basics engine tuning?
Needing to keep the glo-driver connected is probably an indication the carb is set too rich. A new glo-plug is might help, but I'd lean the HSN a bit until it runs without the glo-driver. It should be still rich enough for break-in. The LSN may need attention too, but typically the factory setting for the LSN is never too far away from the final setting.
