RE: Blade SR blade wrappings
Doug,
You still fail to miss the point by an entire mile. Idid not find any of this fun at all. Maybe you did.
Now, you are just being patronizing. I don't need your pink paper or your perfume, Ijust expect you to act like a human being. Instead, you insist on being cute.
So, keep you gift, Idon't need it. Apparently, I was not the only one who thought you were rude, Bldrums gave you the same reponse in another thread.
For what it is worth, I finished up the blades. I pulled off the chipped monokote and put three coats of good old ratte can white on them. Put them all back together and they fly fine. You can see a fine bit of wood grain in the paint, but who cares. The only thing wrong with that set of blades was the monokote was lightly chipped at the end. I did not want to scrap them because Igot tired of hearing the flap whiz in the wind. Iweighed them on my digital scale and they came out about 1.7 grams lighter than a stock blade. This, because I did not put on 3 coats of primer, wood filler and paint. So, the weight is fine and it flys just fine. They will work for now and when I quit setting my SRdown on a slick floor and sliding into chair legs, I will put on one of my 3 remaining good sets and get her back to factory new.
Ihave read some of your other threads, you seem to have some good knowledge and a genuine interest in helping people normally, but in these two threads, you showed your ass.
As for sensitive and the politics comments, Iam far from sensitive and yes, a HARDRIGHTRepublican. Imake no apologies for either, although I have no idea what that has to do with our discussion. Your messages say you have served your country for years, so I would guess military, if you are a military liberal, you are a true genetic anomoly.
C
