RCU Forums - View Single Post - Walbro's with accelerator pumps.
Old 04-29-2010 | 06:18 PM
spaceworm
Default RE: Walbro's with accelerator pumps.
I just found out that you have to add the dash after the WT before the number to get Order Tree to recognize the number. eg, WT-456-1
(WT 456-1 won't work)
QUESTIONS:
1. How do you get the plugs (item 11 on the illustrated parts diagram) over the needle out so you can adjust the needles.
2. Also, just what is a typical part number for the accelerator pump, on say the WT-456-1 carb?
3. On a carb with only the low needle, can you drill and tap the housing for a high speed needle?
