ORIGINAL: Campgems
The cowl doesn't mean much. It could be mounted a little off by it's self.
Agreed. The cowl is set to be true to the engine/spinner thrust ring whether it has engine offset or not. The prop shaft should always be centered in the cowl opening for appearance.
