RE: VRC BigBore Pipe Users
I never thought of cutting an allen key. Good call logon. Sometimes some of the most simple ideas just slip right on by. I still might use the stud idea. It definitely seems more convenient for taking pipes off and putting them on. We'll see. I appreciate all the help.
As far as the spring goes, I should just be able to use the spring from the other victory pipe, right?
teamchrome, how long are the set screws that you used? Are they 30 or 35mm like in the kit, or did you use a different length?
