ORIGINAL: RevyMaxx
Thanks, Doxillla!
AUW is 14.75 lbs...a little shy of what Byron had you shoot for, 15-15.5 lbs. I am itchin' to get'r in the air, waiting on the Dubro pull pull.
Two of these is what I'm using, muhahaha...
http://hobbyking.com/hobbyking/store...00mAh_5S1P_40C
That is a GREATA weight. Most of the g-38. Q-35 powered versions came out to be around 18lbs , econokoted.
