RE: GP Lancair ES Pictures
Here's a few more of my build and assembly pics I took with my cell phone. You can see the 6mm grey depron foam I used for the dash above the instrument panel. The instrument panel is 3m'd to the light ply panel I shaped to fit it. I had to epoxy a couple of pieces of light ply with large triangle stock to the inside walls of the fuselage to give me somewhere to screw on the panel. I glued the depron dash to the panel with foam safe medium CA once it was in position. Now if I need to get to the fuel tank, I just have to take out the panel screws and pull it forward. The dash isn't glued to the fuse at all, just to the instrument panel. I also spent hours upon hours sanding the blue paint and all the thick paint lines off the fuselage. I had to get out the black and decker mouse sander!- Tim
