RCU Forums - View Single Post - How do you temper aluminium?
Old 05-01-2010 | 10:11 AM
Lnewqban's Avatar
Lnewqban
Default RE: How do you temper aluminium?
tipstall 131,
Try heating up and then insulate it from air, so it cools down as slow as possible.
If the aluminum is the proper alloy, it will work.
If not, you could glue (with any metal glue or epoxy) a semi-gear just under this one, overlapping only the critical bending zone near the fuselage.
