RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 05-01-2010 | 07:04 PM
  #816
MTK
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: MTK
ORIGINAL: cmoulder
If I recall correctly, ghoffman reported close to 10k rpm with a Vess 18x6 and a pipe.
No matter how quiet the exhaust is, that prop at 10k is gonna make one heckuva racket!!
Absolutely. I got 3 in this afternoon using the 18.1x10. I don't think I ever got above half throttle. To be fair, half throttle on my set-up opens the butterfly about 70%. In other words, half throttle is more than half power, more like 3/4. Regardless, the prop is just not enough load. Quite loud compared to glow (same prop). A good break in prop tho, for a piped set-up in a pattern plane.
Top speed in the air had to be at least 8400. It was ripping pretty good. The plane is a very light load compared to what I've been running the SAP in, both in terms of weight and in terms of drag. And BTW, today was pretty warm down here, around 90F and more muggy than we have ever run the engine in before. No problems I could tell...handled great
One good suggestion from today's gallery was to use a 3 bladed prop. I think I have a 15.75x13 3B stock. Worth a try. I need to quiet this thing down
I want to rephrase...it is loud because the prop is being turned too fast compared to the glow set-ups I've used before (Webras mostly, 145's and 160's). The glow set-ups were set-up to turn 8K or less on the same prop. The Webra 160 really turned this prop with great authority and in fact I modified the prop by increasing diameter to tame the engine as I recall. I have a similar situation with the SAP but possibly even more so...almost too much speed in my plane.
I wish I had a way to govern rpm electronically (like the electron users). Throttle alone won't really do it. I need to discuss with Ed. Or maybe I just need to run it more to get used to the new characteristics....
