Which battery type?
I recently had my v6 ECU upgraded by JetCat to use A123 batteries. On the GSU battery setup, I only see options for NiCad and LiPo. What battery type should I select to set it for A123's? Also, my motor is an older P80. When the GSU boots, I see P120 on the startup screen. Do the P80 and P120 use the same program or do I need to have it re-flashed.? Thanks ...
Never mind ... called JetCat and got the info.
