RCU Forums - View Single Post - Nitroplanes tucano weight issue
Old 05-02-2010 | 04:50 PM
opjose's Avatar
opjose
Default RE: Nitroplanes tucano weight issue
Are you sure your loading calculations are correct?
I find that most RC models will sustain a 33% weight increase or more without doing too much damage to the flight charactersitics.
As a result I often load down my planes with large 3800mAh NiCD or NiMH batteries to give me long flight times and better wind penetration.
46oz/in is analogous to a loaded warbird.
The Tucano's straight wings will help prevent uncommanded snaps, so from your perspective all you may see is a need to maintain some throttle on landing and faster speeds than what you are used to.
I hope you have at the very least a 500' runway available.... I have a few planes that take the full 500' to come to a stop, and even then need a bit of left and right goosing of the rudder to get them to slow down.
