RCU Forums - View Single Post - recovering help needed
Old 05-03-2010 | 12:53 AM
heavy metal thunder
Default RE: recovering help needed
A real cheap oil removal solution would be to mix rubbing alcohol and corn starch into a thin paste and apply it to the area. Apply the mix and let it dry and brush it off. Continue the process until the mixture dries into a white powder, at that point nearly all the oil should be removed out of the wood.
