Hi BiggTony
I did get another battery and with a fresh charge the fan did start. Im a bit worried about that as the first battery was at about 70% Ireckon....at which point the fan wouldnt spin.
That surely has implications (if I could get the tank running)for the safety of an RX18 with a fan mounted on the main circuit?
I have actually a 9v circuit in the tank for driving the fan under the engine deck (with its own switch)and reckon Imight either set up a circuit for the RX18 fan in a similar way or stick the RX fan on the circuit for the engine deck fan.
On another thread a poster called GeirMagne mentions measuring voltages on the "pcb's".....does anyone know what these voltages should be ?
This is the thread:
http://www.rcuniverse.com/forum/m_95...tm.htm#9560455
He had the same problem as me but did not post if or how he resolved it..... (there should be an obligation on people to eventually report how problems were solved!).
p
