RCU Forums - View Single Post - Prop shaft question
Old 05-03-2010 | 02:32 AM
repirazz's Avatar
repirazz
Default RE: Prop shaft question
ORIGINAL: drube
That makes sense, I noticed it after the prop was offsoI'll check it again when the prop is back on and let you know. Thanks for the diagram!
What he's describing is normal when the props unbolted. At first I wasn't sure if he had the prop on or off. It'll be good to go once everythings bolted up tight.
-rep
