RE: General Homie Forum
Yep, that clutch IS the nut. You can screw it on to protect the threads while you whack the crankshaft end. Screw it on until the top of the clutch is flush with the threads on the crank if it will go that far without actually touching/putting pressure against the flywheel. Later, your prop hub will screw onto those threads where the clutch once was.
AV8TOR
