RE: OS motor
they are both good motors...if you can afford the AX id go with that one...its like comparing a stock v6 mustang against a stock v8 GT...the AX has dual ball bearing while the other is bushed.... If you go with the AX, you can use it in second plane, perhaps a more sporty one that can use the extra power
Typically most learn on a 40 size trainer
