RE: Duratrax Axis Engine Replacement Help!!!!!!
Sure you can rig something up, but you will have to find another flywheel and clutch-nut. The Axis has an odd motor mount; I use it the break-in my new motors, but can not line-up the clutch and the spur gear exactly right which causes the plastic spur gear to strip, because the set-up is for a treaded crank engine. You may have to also replace the motor mounts.
