RCU Forums - View Single Post - KillerVolt
Thread: KillerVolt
Old 05-04-2010 | 11:51 PM
HRCules77's Avatar
HRCules77
Default RE: KillerVolt
I wasn't very happy with the receiver box since it was left open to dirt and debris, so I made a few changes that I'm very happy with now.
1. I closed in the box using white styrene plate and strips but for clearance reasons used a thin piece of .030 carbon plate on the bottom.
2. Here you can see the rear of my patchwork: everything has been CA'd together.
3. Since I kept the original piece I cut out of the servo box, I used it as a cover. I also used the rubber seal that came with the original receiver box and custom fitted it into this project. A tiny screw holds the cover on.
ID:	1430998   Click image for larger version
ID:	1430999   Click image for larger version
